PSI & Air Temperature . . .
Our home elevation is 25 feet above sea level. We spent the weekend at 7000 feet above sea level. The A4 sat undriven for two days and nights while we hiked, etc. Overnight temps were in the 30's, and daytime temps were probably in the 50's.
We got in the car on Sunday afternoon to drive home, and about 25 miles down the mountain, one of our tires blew out. When I took it in for repair, the tire shop said that the tire ran too long at a depressed pressure.
I figure that the combined effect of altitude (thinner air), reduced temperature, and lack of use for two days depressed the tire pressures to an all time low.
So, yes, I agree with you; I think that outside temps do have an effect on pressure, but only if your tires have had a chance to adjust to those temps.
You lose about 1 psi per 10 deg F drop in temperature. You probably gained 1 to 2 psi from the altitude.
Sounds like it was seriously cold and/or you had a leak and/or you hadn't checked the tire pressures in a while.
- Tom
The cold temps and elevation actually oppose each other with relation to tire volume...if the elevation is great enough, the tire could explode due to high volume inside...if the cold is great enough the tire could deflate significantly.
If your tire wall blew out because of alleged low pressure, it was certainly because the wall had been weakened by a very prolonged time at low pressure. Most people drive around, unknowingly, with one or more of their tires seriously deflated for months and months and don't have blow outs...I don't think 2 days could do it. Perhaps the blow out was due to the high elevation causing expansion, then when you started driving, the tires heated up more causing more expansion and KABOOM!
- Tom
