What is the offset for the 4.2? 35mm or 40mm? I'm looking at buying 40mm rims. Do I need spacer? ..
Old Jan 8, 2002 | 04:24 PM
IsuedAoAand1's Avatar
Junior Member
Default What is the offset for the 4.2? 35mm or 40mm? I'm looking at buying 40mm rims. Do I need spacer? ..
Anything bad about spacers? I have the sport package now.
Thanks
Old Jan 8, 2002 | 04:29 PM
Brian-PA's Avatar
4.2 Offset 35mm.
Old Jan 8, 2002 | 05:22 PM
Junior Member
Thanks!
Old Jan 8, 2002 | 05:38 PM
CarmG993's Avatar
Default What wheel did you decide on?
What wheel did you finally decide on?
I've heard mixed comments about spacers, if they are from reliable source/good quality, should have no issues.
Old Jan 8, 2002 | 05:51 PM
Junior Member
See my above post. I CANT DECIDE and it's driving me CRAZY! Leaning towards RT's
Old Jan 9, 2002 | 06:23 AM
Brian-PA's Avatar
Default IMHO, you will not be disappointed with the RT's. . .
they are strong, relatively light, and very durable because of their design. Without the wide flat surfaces at the edge of the wheel plane scratches are less noticeable.
I use the RT as a winter wheel 16" and it will look nice in a larger diameter. It looks fine in 16" but would look better if it were larger.
Also, it is easy to replace if one gets damaged. I have been through more wheels for various reasons with this car than all cars I owned combined in the previous ten years.
Brian
SRTTT
Mar 12, 2007 08:26 AM
maclem8223
Feb 6, 2007 02:56 PM
shwndh
Wheels & Tires Discussion
Jan 30, 2007 11:40 AM
esanmiguel
Jan 24, 2006 05:11 PM
STEALTH_6
Nov 4, 2005 05:56 PM
