Slotted vs. Cross Drilled
Manity
Cross drilled does work very well on the track. Slotted works well, but not quite a match for drilled - doesn't seem to have the cracking issue.
In our 990 lb Formula Continental, we do use drilled rotors, but for the weight savings; and as you can see in the photo, we remove as much metal as possible.
<img src="http://pictureposter.audiworld.com/17157/drilled.jpg">
The holes are all chamfered to minimize cracking; but as April points out, at the end of a season these rotors must be replaced because of the cracks that initiate at the holes.
IMHO, drilled rotors on a street car are only useful for cosmetics, in spite of Brembo's use of drilled rotors on Porsches. They don't provide any advantage over slotted rotors and are prone to cracking.
I needed to do my brakes and upgraded to slotted rotors in front and Rofren pads all the way around. I had to do the brakes and took the money I saved by doing the work myself and put it into a slight upgrade.
<img src="http://pictureposter.audiworld.com/12414/driverfront.jpg">
<ul><li><a href="http://www.kvrperformance.com/newpage4.htm">KVR Performance</a></li></ul>
http://www.nsxfiles.com/NSX_mods.htm
Ford boys with big motors.
http://www.shotimes.com/brakes/part2.html<ul><li><a href="http://www.surrealmirage.com/subaru/brakes.html">Direct response to KVR</a></li></ul>
We certainly replace the drilled rotors on our FC long before they look this bad!
