Can you chip a 3.0?
http://www.upsolute.com/database/english/sheets/482.html
-C
Most chips will only adavance timing or play around with fuel/air mixture. Most tests in the mazagines yield no significant gain in performance but often just improve throttle respond and make engine rougher despite what the chip manufactures claim. Only turbo car would benefit greatly from a chip mod. A chip mod for 3.0 would be more significant if the chip is designed with after market air filter or exhaust in mind to maximize each mod. Otherwise, no way in hell would I chip a 3.0, the same money you spend you could probably be drining the 2.7tt
