Oil leak and new cam seals/gaskets
Old Sep 21, 2002 | 10:34 AM
newbie2.7T's Avatar
Default Oil leak and new cam seals/gaskets
Can't believe I only have 33K on my 2001 A6 2.7T and it already had a major oil leak.
Dealer diagnosed the problem as leaking CAM seals and gaskets, so both were replaced under warranty. Anyone experience the same problem? Is there any special break-in period with new seals/gaskets? I.e., do I need to drive easy for a while?
Wondering if this is a common and reoccurring problem on 2.7Ts.
Thanks much,
Ed
Old Sep 21, 2002 | 10:56 AM
2.7tDallas's Avatar
AudiWorld Expert
Default I had both cam covers and valve covers. It is not the CAM SEAL. There is no such thing. It is
the CAM COVER is an additional smaller valve cover type area. If the cam cover seals are bad - I would expect the valve covers to be next. Watch that dipstick
Old Sep 21, 2002 | 01:41 PM
newbie2.7T's Avatar
Default Re: I had both cam covers and valve covers. It is not the CAM SEAL. There is no such thing. It is
Thanks 2.7Tdallas. The service manager termed it that way. The parts used were:
GasketSet, Clip, Gasket, Cover, and Grommet. So I guess it was the cam covers and valve covers. The question I have -- is there a break-in period I should follow after the repair? Or new seals don't require a break-in since no internal mechanical parts were replaced.
Thanks!
Old Sep 21, 2002 | 02:28 PM
2.7tDallas's Avatar
AudiWorld Expert
No break in for gaskets. Just for new 2.7t owners! ;-)
Old Sep 21, 2002 | 08:56 PM
DarrenCT's Avatar
36k on my 2.8 tensioner seals and main seal on rear of eng leak 8(
AudiEnthuz
2.7T V6 Discussion
Feb 20, 2011 10:45 AM
STTPower
13
Nov 30, 2005 02:11 PM
