18 inch wheels
Old Apr 9, 2003 | 11:57 AM
bear1906's Avatar
Default 18 inch wheels
I am in the process of looking at aftermarket rims...I left a couple of posts for info...not alot of replies...
I would like to know the following:
Can I put 18" wheels on a 99A6 Quattro with stock suspension...
If so, what are the tradeoff, how much shorter does the tire last mile wise....
Let me know!!!
Old Apr 9, 2003 | 12:10 PM
myfirstimport's Avatar
Default Depends on the tire
If you get a soft tire, it will not last as long.
you can do 18's with stock suspention.
Trade off is a stiffer ride, a bit harsher , but a welcome trade to the floating stock ride.
Old Apr 9, 2003 | 12:13 PM
Waiz One's Avatar
New Member
Default If your running 16's, your going to want to do a plus 2 conversion,
which means go up 2" in wheel diam, and down accordingly in tire profile - ie 16" rim with 60 profile = 18" with 40 profile. With larger tires you won't necessarily get worse wear, but your tire options will be limited to performance/ultra performance which typically are softer by nature.
Old Apr 9, 2003 | 12:32 PM
DUBITUP's Avatar
Default Correct Wheel/Tire combo is: 18x8 235/40/18
I think that this will give the smallest margin of error to the speedo.
Old Apr 9, 2003 | 12:46 PM
245-40-18 is a 1.5% rolling diameter difference than the stock 16 in set up.
Old Apr 9, 2003 | 01:25 PM
bear1906's Avatar
Default Re: Depends on the tire
So are 17's the better compromise?
Old Apr 9, 2003 | 06:09 PM
Singletrack's Avatar
But 245s might soften up the ride nicely also.
Old Apr 9, 2003 | 08:17 PM
BryanR2.7T's Avatar
Member
Default 265/35-18 is 0.12% difference from my stock 235/45-17
<center><img src="http://pictureposter.audiworld.com/36363/tread.jpg"></center><p>Stock rim is 7.5 wide and these are 18*9
 Pouria Savadkouei
 Michael S. Palmer
not_depressed_owner
21
Apr 27, 2005 04:36 PM
DolphinA4
Aug 5, 2002 07:15 PM
AusTTn
Apr 8, 2002 03:45 PM
a4quandries
9
Mar 27, 2002 09:54 AM
