Yes another RS6 rim on a 2.8 question...
Old Apr 10, 2003 | 11:12 AM
AudiForYou's 4.2's Avatar
Junior Member
Default Yes another RS6 rim on a 2.8 question...
245/45 tire on an 18 x 7.5 wheel on a 2.8 A6
I know the max recommended size is 235/40 on an 18 x 8, but could the smaller 20 mm offset of the 7.5 wheel vs. a 35 mm offset of an 8 make it a reality?
I can't help but ask, I see them, I want them...
Old Apr 10, 2003 | 11:24 AM
Finman's Avatar
Default The offset has no effect on how wide of a tire can fit on a particular rim...
Why not just put 235s on 'em?
Old Apr 10, 2003 | 11:26 AM
Junior Member
They are used rims with 245's... I was hoping smaller offset would mean a 245 wouldn't rub outside
Old Apr 10, 2003 | 11:33 AM
Finman's Avatar
Default If they fit, they fit...
Have the tires successfully been mounted on these rims? If so, I guess they are fine especially if they've been proven to fit well with some miles on 'em.
I don't think 245s should pose much problem with the outside fender...obviously depending on the offset...but if the offset is too low, you might have problems with the tire rubbing on the inside...and along the upper suspension arm.
Old Apr 10, 2003 | 12:16 PM
Junior Member
They'r mounted, just unsure 245/45 will fit a 2.8. 45 may be tall & 245 too wide rgrds of offset
Old Apr 10, 2003 | 12:35 PM
Snowtoy too's Avatar
Junior Member
Default Are these a set of the RS4 "winter" tires and rims ??
If so they will fit.. or so I've been told by folks from Germany. But they don't fit a 2.7t or 4.2.....
regards,
Old Apr 10, 2003 | 12:36 PM
Finman's Avatar
Default Yeah, tough to say...it's 5.4% too "tall" of a diameter...which might cause rubbing...
You'd obviously be much better off with 245/40s or better yet, 235/40s.
Only one way to find out.
My 19 inch RS 6 wheel and tire combo is 4% too large...and the clearance is close with the upper suspension arm...quite close...that doesn't mean anything about your situation other than you gotta just check it out first...
Good luck...
TeddyBGame's Avatar
Default RS6 19" will fit fine on a 2.8. I just followed Finman's lead....Too bling-bling though.
<center><img src="http://ebay3.ipixmedia.com/abc/M28/_EBAY_cb6e43e9672b9e7341fdee9aa960d5d1/i-1.JPG"></center><p>just kidding.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 10, 2003 | 01:19 PM
Finman's Avatar
Damn! That looks really sweet! Minimal bling!
Old Apr 10, 2003 | 02:36 PM
Audi S5 TC's Avatar
Default Hey Finman
With your 19 inch RS6 wheels, do you have 255/30R19 tires or 255/35R19 tires?
