Clear Turn Signal Question ->
BTW, I am taking it to the dealer this weekend for the service recall. Wish me luck, I am going to beg and plead for a new bumper. Any advice on that topic would be helpful as well.
-st
I used to have pics on this, maybe someone saved them...let me know if you need any tips...mine came right out after I located that 4th screw.
The 4th screw holds a peg recepticle to the side of the rad. It really isn't meant to be removed as you can get the lights out with the bumper off. I had to use an L-shaped torx put to get at it (T30 IIRC - but not sure).
If you look at the headlight out of the car there are three mount points really:
1. The 2 screw tabs on top.
2. The 1 screw off the back right that you have to access through the 1/4 panel hole.
3. The peg on the back left of the housing that slides into the recepticle on the side of the radiator.
Hope that helps,
-st
