CEL after Unplugging Throttle Body
Old Apr 11, 2003 | 01:46 PM
ThrottleBoy's Avatar
New Member
Default CEL after Unplugging Throttle Body
A question for the enlightened...
Sequence of events:
-bought 2000 A6 2.7T, six speed, 55K, runs great
-6 weeks of high performance then Check Engine Light appears
-in for service... code suggests Fuel Trim Issue
-discover crack in rubber Y boot at the inlet of the throttle body. Tech bulletin helps find problem.
-tech fixes problem. Unplugs Throttle body to do so.
-drive off lot only to have CEL return about 3 miles down the road.
-computer now throwing many codes including: cylinder misfire, idle control systems, and fuel trim... oxegen sensors say LEAN
-tech baffled... me frustrated.
Any ideas???
Old Apr 11, 2003 | 01:57 PM
Richard Solomon's Avatar
Tech Guru
Default Bad MAF
17536 and 17538 are almost always a bad MAF.
Old Apr 11, 2003 | 02:05 PM
New Member
Default Re: Bad MAF
Excuse my ignorance but what exactly is the MAF?
If this is the issue, what am I looking at financially.
Thanks for your opinion.
Old Apr 11, 2003 | 02:10 PM
Tech Guru
Default Mass Air Flow sensor
Mine was replaced under warranty, but I think they're ~$400! Search archives for MAF and you'll find a ton of info...
Old Apr 11, 2003 | 02:12 PM
Tech Guru
Default Was it an Audi tech or an independent?
An indie may not have known to rerun a throttle body adaptation with his VAG tool.... suspect you'd want/need that done after touching the tb.
Old Apr 11, 2003 | 02:46 PM
New Member
Default Re: Was it an Audi tech or an independent?
Independent.
If in fact the tech failed to run the throttle body adaptation, is it still your guess that the MAF is bad?
Thanks again
Old Apr 11, 2003 | 03:03 PM
Tech Guru
Oh yeah, just might explain other codes
Old Apr 11, 2003 | 04:27 PM
Singletrack's Avatar
Default Get the exact codes from him and we can help more : )
Fuel trim - system too lean is usually a bad MAF or a leak in the intake. I'd be speculating on the rest, so try to get the exact codes from him.
-st
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 11, 2003 | 05:24 PM
BasicSlvr's Avatar
NOT that bad,,,just paid 200 for a new MAF.
Krueger
Feb 15, 2012 08:56 PM
Slipstream30v
Dec 6, 2005 09:35 AM
ashwins
Jun 5, 2005 07:35 PM
micke
VAG-COM Discussion
Apr 3, 2003 04:56 AM
bretto
Mar 13, 2003 05:23 AM
