S6s second trip to the dealer in 5200 miles!
Old Apr 14, 2003 | 05:08 PM
Northern Ivy's Avatar
Default S6s second trip to the dealer in 5200 miles!
Well the S6 was back in the shop today for the vibration that occurs only after hard acceleration and then holding a speed of 72 mph....Oh well tire balancing last about 3 days last time, we will see what happens this time.
Since it was in at 5200 miles I did my first oil change as well.
Mobile 1 0w-30 4.89/quart (8.5 used)
1 OEM Oil Filter $40.00
16 mins labor 24.00
Total= $105.57
Does this seem about right? Also is there any online vendors that have the "Oil" or filter for less?
Ad Amsol (sp) hold up better then M1 in the S6?
Thanks for the help!
Old Apr 14, 2003 | 05:13 PM
Finman's Avatar
Default Too much oil used...check your dipstick...
I've found that no more than 7.5-8 quarts is used in the 4.2 engine...
My cars have been overfilled 4 times! (each by ~1/2 quart)
Otherwise, the price is right.
Old Apr 14, 2003 | 06:37 PM
Default Re: Too much oil used...check your dipstick...
What are the risk behind to much oil? Can one remove the overflow?
Old Apr 14, 2003 | 10:10 PM
6sidua's Avatar
Default went throught same first service last year....
s6 should take 8 quarts flat. extra risks foaming and imcomplete cooling of the oil. the filter is big, but 8 is supposed to cover it too.
check oil when car is cold, warm and just hot. all 3 levels should be with the marked band. if overfilled cold checks will be fine but hot checks after a few minutes to drain back, will read above the full mark.
pita to take out extra but if it has some insist the dealer do it, it will not burn off...
castro syn or m1 syn at costco and sams clubs for about 3.60 per quart (6 for 22-23$)
filter is assembled for each use and very hard to access (remove belly pan ) so easier to have dealer do, just take the oil. many dealer will give a 10-30% discount on parts for aoa members, so that's the best way to get parts -other than clairparts.com
stardard schedule is very long for all paid service, so you'll likely want to pay for things more ofter. example air filter is 40k or 2-4 years? waaaay to long. fresh air filter is also twice the scheduled time than for the 2000-01 year...
cheers
njoy
Old Apr 14, 2003 | 10:11 PM
6sidua's Avatar
also my same shimmy was only fixed with 4 new tires, after several balance/rotation trials....
Old Apr 15, 2003 | 04:25 AM
Edd W's Avatar
Default If it is over-filled, it is possible for oil to go straight through...
the crank breather system into the inlet manifold. This then gets burnt and does not do the Cat's any good. If it is only a very small amount, this is unlikely, the main thing it causes is a bit too much splashing around in the crank-case which means it will probably burn it a bit quicker due to too much getting up the cylinder bores.
If it was severely over-filled, ie ½" over max on the dipstick, then it could cause mechanical damage as well, due to the risk of large amounts of oil getting through into the combustion chamber causing the risk of an hydraulic lock = bent con-rod. It will also cause extra oil leaks, over and above the standard Audi OEM ones.
There are three ways of removing some oil - suck some off through the dip-stick tube with a special suction system - some workshops have them, unscrew the oil filter and drain that will remove about ½ pint at a time, or remove the drain plug - this is likely to drop the whole lot.
Old Apr 15, 2003 | 04:32 AM
Thanks for all the help!!!!
Old Apr 15, 2003 | 04:35 AM
Default Just Curious....
Were the 4 new tires provided as prat of the warranty? I have described this problem to my service advisor from day one. Seems to me that if it were to be tires, they would be under warranty.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 15, 2003 | 05:27 AM
DesmoTesta's Avatar
Buy oil filters from Clairparts.com..much cheaper
Old Apr 15, 2003 | 06:14 AM
RichP's Avatar
Junior Member
Default Shoulda got an allroad!
j/k
You running your stock wheels and tires?
Did this happen with the 18's too?
