Should I use an OEM oil filter or a Gold filter from NAPA? Any pros/cons for either?
Old Apr 15, 2003 | 07:32 AM
DJ 2.7T's Avatar
25 Year Member
Old Apr 15, 2003 | 07:42 AM
LCP's Avatar
LCP
AudiWorld Expert
OEM! The vast majority of aftermarket filters SUCK!
Old Apr 15, 2003 | 08:04 AM
AudiForYou's 4.2's Avatar
Junior Member
An OEM Bosch or Mahle filter from thepartsbin.com - save yer nickels...
Old Apr 15, 2003 | 08:17 AM
frankie@work's Avatar
Member
Default Not true. Most branded aftermarket parts "meet or exceed" OEM specs.
Even many "house" brands of parts ie. NAPA & CARQUEST are in many cases of higher quality than "OEM". I've worked in the aftermarket for nearly 20 years.
Old Apr 15, 2003 | 08:24 AM
ar2002's Avatar
Junior Member
Default I understand many Audi engines run a quite high oil pressure requiring a specialized filter...
I'd really want to be sure the filter was up to Audi specs. for your particular engine, even though NAPA Gold filters are considered to be rather good.
My understanding that Audi/VW filters are made by the European company, "Mann", and are designed to handle the high-volume high pressure Audi oil pump with a bypass valve opening of 20-33psi, depending on application. You can get these from www.Audiquattroparts.com for $13 USD for the A6, for example.
Old Apr 15, 2003 | 08:27 AM
LCP's Avatar
LCP
AudiWorld Expert
Default I was going on information from this oil filter comparison study...
...that was done by someone not affiliated with any of the companies. Sure there were some good filters, but there were also some lousy ones, and the VW/Audi OEM filter is a good one to begin with, so why take any chances unless you know about the specific filter you're going with.<ul><li><a href="http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html">http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html</a</li></ul>
Old Apr 15, 2003 | 11:10 AM
phred's Avatar
Senior Member
Default Wrong place to save money
Get an Audi OEM filter. IMHO.
Jiggsy
25
Mar 16, 2007 06:37 PM
jguthrie
Dec 30, 2004 07:00 PM
sNoSTaRR
Oct 17, 2003 12:07 PM
Dave Griswold
Feb 20, 2003 04:12 AM
faust92
Jan 10, 2002 01:19 PM
