What to look out for on a '00 2.7T?
Old May 7, 2003 | 02:33 PM
DC2.7T's Avatar
New Member
Default What to look out for on a '00 2.7T?
I am thinking about purchasing a 2000 A6 2.7T with the 6 speed. I've tried searching on here to find out what to look for, but have not had much success. I am mainly interested in knowing if there were any major problems and what I should look out for when buying.
I think I heard that early '00 models had problems with turbo failure. Is this correct? Does the A6 have the same issues with the control arms that the B5 platform has? I'm sure it is safe to assume that I should look into an extended warranty if reliability is anything like the '97 A4 and '99 Passat I have. Thanks for any and all help.
Old May 7, 2003 | 02:39 PM
light27t's Avatar
New Member
Default Re: What to look out for on a '00 2.7T?
You want one built after Feb or Mar 2000. You want one still under warranty now so you can stick Audi with any immediate problems. You probably want to purchase an extended warranty. There's a some recall work that hopefully was taken care of - a dealer can look up the car. You probably want to stick the seller with getting you new tires if the originals are still rolling around. And you want a new front bumper cover! Mine has been flawless.
Old May 7, 2003 | 03:28 PM
Chris JB's Avatar
Default My early '00 2.7t has had no problems...
with turbos or control arms. I now have over 64,000 miles and completely love the car!
Chris JB
Old May 7, 2003 | 03:43 PM
2tu®bos1mission's Avatar
Default The control arm prob was fixed on both the A4 and A6 in 2000, so that should not be a prob.
The turbo prob is the biggest on the 2000's like with the S4. Turbo failures on stock cars 01-03 are almost non exsistent. I'd get a good warranty. Good luck!!
Old May 7, 2003 | 03:57 PM
DC2.7T's Avatar
New Member
What is the issue with the front bumper cover? Thanks!
Old May 7, 2003 | 04:12 PM
light27t's Avatar
New Member
You can learn the epic of the peeling bumper cover if you search 'bumper' in the forum
Old May 8, 2003 | 05:01 AM
A6 Bandit's Avatar
New Member
Default Re: The control arm prob was fixed on both the A4 and A6 in 2000, so that should not be a prob.
How could you tell if one of your turbos have failed ? Or if both have failed? What would driving be like? Is there a way to check this?
Old May 8, 2003 | 01:42 PM
geauxfaster's Avatar
New Member
I posted a question last week about a "moaning" noise coming from my driver's side wheel well. 2.7tdallas mentioned the '00's had tie rod issues, which this might be. I haven't confirmed it yet. 60k miles, 41k of which are mine - no other issues, love the ride.
 Pouria Savadkouei
 Michael S. Palmer
larsenracing
13
May 22, 2009 02:25 PM
A6 shopping
16
Mar 30, 2004 12:51 PM
david in NJ
Feb 17, 2004 05:41 PM
angleman 2.7t
9
Nov 27, 2001 06:33 AM
theanimala
Oct 1, 2001 04:05 PM
