Tire pressure for 235s
Old May 8, 2003 | 11:53 AM
dougs2.7T's Avatar
New Member
Default Tire pressure for 235s
Just mounted a set of ContiContact2 235/45/17 on my 01 2.7T. What tire pressure should I be running? Any comments on these tires? Thanks
Old May 8, 2003 | 12:34 PM
2.7t john's Avatar
New Member
personally i run 38 psi... you can also look in your passenger door jamb and see what audi recomm.
Old May 8, 2003 | 12:51 PM
TXurS6's Avatar
Default I'm running 39 front/37 rear on my 235/45-17 Toyos
When I had the S-03's I ran 40 front/38 rear.
It really depends on your style of driving, how much comfort you want (or are will to give up) and how much rim protection you want. The tire type itself is also a factor. Higher pressures guard against pothole wheel damage but sacrifice ride comfort. Higher pressures also help steering feel and sidewall stiffness for higer performance style driving. Again at the sacrifice of ride comfort.
Old May 8, 2003 | 12:59 PM
Singletrack's Avatar
38/37 37/36...somewhere in there.
Old May 8, 2003 | 01:14 PM
dougs2.7T's Avatar
New Member
Default I am quite surprised
The recommendations on my door jam are 38/42 for 205s and 34/34 for 215s. Judging from these data, the 235s should be running at a lower pressure since the wt of the car does not change but now you have more area (wider tires). I am running 32/32 right now but I will increase the pressure if that is the concensus.
Old May 8, 2003 | 02:20 PM
TXurS6's Avatar
Default Re: I am quite surprised
I think the dooorjamb numbers are recommendations based on the standard tires available from the manufacturer. Different tires have different weight capacities and require different pressures to maintain the weight capacities.
There are a couple of ways to determine the correct pressures for your tires. Here is the one I use.<ul><li><a href="https://forums.audiworld.com/a6/msgs/53203.phtml">https://forums.audiworld.com/a6/msgs/53203.phtml</a</li></ul>
Old May 8, 2003 | 02:23 PM
Doug2.7's Avatar
25 Year Member
38 rear and 40 front...on Dunlop 9000
Old May 8, 2003 | 04:55 PM
ari (audiless)'s Avatar
Junior Member
For me, best ride/handling combo was at 38/38. YMMV, of course.
 Pouria Savadkouei
 Michael S. Palmer
Old May 8, 2003 | 06:41 PM
Yup, or you can eyeball it, just look for the burn marks : )
Old May 10, 2003 | 04:11 PM
duodallas's Avatar
39 is too high. Rough ride, and I bent a wheel in the midwest at39. No problems at 36-37.
jclaib7
Audi A3 / S3 / RS 3 MKII
33
Jun 17, 2016 12:30 PM
taxman1
Audi allroad
19
Nov 17, 2006 07:20 PM
A4Grover
A4 (B7 Platform) Discussion
Oct 20, 2005 05:01 AM
CleanAudi
Wheels & Tires Discussion
Sep 4, 2001 07:19 AM
Big D
May 30, 2001 01:40 PM
