Need Chip Advice
Thanks.
'03 chips are only starting to reach the market in some cases. You will need the ecu number to ensure you get the right version.
Here are my overall impressions. Others may have different experience so feel free to chime in.
Neuspeed - Usually not the smoothest or the strongest, but they are almost always the least expensive. May set off higher than normal DTCs, but rarely causes mechanical harm.
APR - Offers an extensive range of programming options and the ability to switch between them. Decent all around performer. Longest continous history of offering the switching system.
GIAC - Starting to offer programming options like APR. Slightly more aggressive power compared to APR, but sometimes at the expense of making their early customers their test subjects.
MTM/Hoppen - Usually accepted as the most aggressive programming for any single application. Fuss free for most owners from a minor irritation standpoint, but hard on the car mechanically. Works as advertised. Base programming comes from Germany.
Abt/AMS - German tuning from the world's largest VW and Audi tuner. Slightly lower state of tune than MTM, usually with lowest boost/most power combination for the 2.7t. Since the chips must be adapted from German programs, often slow to market with new versions.
OCT - Austrian company new to North America. Looks to have solid background and medium strength output. Only downside is that the importer here does not have a test or repair facility.
I'll state up front that I work for AMS, and do so because when I worked at the dealership, they seemed to have the fewest problems and the best relationship with the service dept.
TIA for the info if you have it,
-st
An example is a recent job with an S4 running stage 5 software. The hardware was externally sourced. The install was done by a shop far removed. The customer had a number for DTCs and thought it might be the software. By carefully backtracking the process on a car in the shop for that purpose, we could figure out that the wastegates were not set at all before installation.
In other cases the ecu exhibits strange characteristics that aren't normal in 99.99% of chips sold. The only way to figure it out for sure, is to install that customer's ecu in a car and see whether it is a software fault, ecu fault, or hardware fault.
The problem is that you run into many variables when you use different hardware combinations and don't know the condition of the car on which they are installed.
