First Oil Change - Which brand?
Old May 9, 2003 | 10:52 AM
Gerno's Avatar
New Member
Default First Oil Change - Which brand?
I've got the first oil change on my '03 2.7T. I will use synthetic. What brands do people recommend? How much will I need? Thanks in advance.
Old May 9, 2003 | 11:06 AM
Gaucho's Avatar
New Member
Default Re: First Oil Change - Which brand?
Go with Mobil 1 / 0-40W and you will need 6.9 quarts. Your change interval should be the factory recommended interval divided by 2. It will cost you more, partcularly since you are likely still on warranty but it is worth it. The engine will keep its tolerances longer and the turbos will love it.
Old May 9, 2003 | 11:13 AM
mike27t's Avatar
New Member
Default First oil change at 5000 or 10000 miles
I have an 03 too. Should I change at 5,000 miles or wait for 10,000. I do mainly city driving. Trip computer tells me my average is 30 MPH.
I also heard that you should do the first couple of changes with Dino and then move to Synthetic at 15,000 miles.
Old May 9, 2003 | 11:23 AM
no.radar's Avatar
AudiWorld Expert
FleetFarm.
Old May 9, 2003 | 11:29 AM
phred's Avatar
Senior Member
Chalet from nearest 7-11
Old May 9, 2003 | 01:07 PM
Singletrack's Avatar
7(6.9) qts - I have been using 5w30 mobil 1- switching to 0w40 mobil 1.
Old May 9, 2003 | 01:08 PM
BS about the dyno to synth crapola IMO. I change oil every 8k miles or 6months.
Old May 9, 2003 | 02:19 PM
ar2002's Avatar
Junior Member
Default I'd change to Mobil1 0W30 at 5000 miles...
I'd change to Mobil1 0W30 at 5000 miles - it has better specs than 5W30 - and then change it again at 10,000 miles to either M1 0W30 or M1 0W40. I think that the 0W40 is good enough to last 10K in large-sump 2.4 & 2.7t engine; not so sure about 0W30.
Use the OEM filter - they're good.
 Pouria Savadkouei
 Michael S. Palmer
Old May 9, 2003 | 02:30 PM
UTQuattro's Avatar
New Member
Why 0W40?
Old May 9, 2003 | 02:33 PM
Default It's one of the only oils that meets all the specs in the manual for one...
Lots of info on it though, especially on the S4 forum if you are interested.
-st
