97 A6 Front Ball Joint Removal, help.
Old May 11, 2003 | 02:45 PM
jlag's Avatar
Default 97 A6 Front Ball Joint Removal, help.
I am removing the ball joint in order to remove the axle shaft. The bolt is out, I pry the arm down, the joint comes out about an inch, but no more. I have a jack under the hub, have tried jacking the wheel up quite a bit, standing/jumping on the pry bar but still no budge. It seems to be binding in the hole. I am going to loosen the sway bar on both sides of the vehicle next in order to get some more play in the system, perhaps loosen where the control arm bolts into the frame. Any ideas would be appreciated.
Old May 11, 2003 | 04:27 PM
jc's Avatar
jc
Default Might want to try the old A6/100 Forum
Link below<ul><li><a href="https://forums.audiworld.com/a6100">A6/100 Forum</a></li></ul>
Old May 11, 2003 | 07:42 PM
jlag's Avatar
Thanks, sorry.
rhodesrt
Audi 100 / A6 (C4 Platform)
Jan 5, 2010 04:27 PM
JMS-Four
Feb 21, 2007 12:34 PM
Bigstauf
Feb 14, 2005 05:52 PM
jlag
May 12, 2003 04:00 AM
audiluver
10
Mar 21, 2003 04:57 AM
