Small fan noise from within engine....Not siren like others have had
Old May 13, 2003 | 07:11 AM
vpr1980's Avatar
Junior Member
Default Small fan noise from within engine....Not siren like others have had
I just noticed this yesterday when I was driving around without the radio. Under hard WOT acceleration after about 4K RPM it sounds like a little fan goes on under the hood. Its making a noise like its hitting something as it spins. Its kinda quite but you can still hear it. Then after I drop below 4K it turns off. Also it only does it under hard acceleration and not just normal cruising with high rpms.
What could it be?
Old May 13, 2003 | 08:04 AM
Singletrack's Avatar
Default Staring at the engine bay from the front, look down and slightly to the right.
Make sure the fan is not hitting the black plastic pipe coming from the driver side intercooler. That would be my guess. Clearance is going to be tight no matter what, but there should be some clearance.
-st
Old May 13, 2003 | 09:47 AM
vpr1980's Avatar
Junior Member
If thats the case wouldn't I hear it all the time and not only when pushing hard.
Old May 13, 2003 | 10:37 AM
Possibly, but the engine does move slightly under load.
panicfilms
Oct 28, 2002 11:35 PM
Paul3.2A4avant
Audi allroad
Apr 18, 2002 06:44 AM
Leon7
Jun 3, 2001 06:53 PM
rj_2.7T
Jan 24, 2001 08:40 AM
JKM
Nov 2, 1999 08:20 AM
