CEL solved! I am also dumb.
Old May 13, 2003 | 07:26 AM
dejavu's Avatar
Senior Member
Default CEL solved! I am also dumb.
CEl came on a few days ago and almost lost a relationship becuase I was paying more attention to the car then the GF at the time. Well, after checking the AW archives, many posts pointed to checking the gas cap to be certain it is on all the way. I checked, and found no gas cap! $16.25 later, new gas cap on, no more CEL!
Old May 13, 2003 | 07:35 AM
saabSean's Avatar
Default Re: CEL solved! I am also dumb.
How did you lose your gas cap?? Audis have had notched gas caps for a long time, they sit on top of the fuel filler door when it's open. With the cap on the door, you'll never lose it.
Old May 13, 2003 | 07:52 AM
2.7t john's Avatar
New Member
Dejavu...are you in ct. ??
Old May 13, 2003 | 08:50 AM
dejavu's Avatar
Senior Member
Seattle, WA
Old May 13, 2003 | 08:52 AM
dejavu's Avatar
Senior Member
Default I normally put the gas cap on top of the pump
I guess this time, I forgot to twist it back onto the car.
Old May 13, 2003 | 08:57 AM
saabSean's Avatar
Default Re: I normally put the gas cap on top of the pump
Try placing it on the door, you'll never lose it again.
Old May 13, 2003 | 10:11 AM
gdog009's Avatar
Senior Member
Default wait... how do you NOT...
nevermind
glad your CEL solution was quicker/cheaper/simpler than mine (Torque Converter replacement at about 30k mi.- under warranty at least...)
Old May 13, 2003 | 11:53 AM
SloopJohnB's Avatar
Junior Member
Default I use the cap to operate the handle.....
It's just the right size to jam the nozzle on on those nozzles that have the autofill disabled.
Of course, one should, ahem, 'watch' the nozzle as the tank is being filled just in case the autofill notch piece was removed for a reason.....
Shut the pump off quickly if it overflows, doesn't shut off at the nozzle!!!!
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 17, 2003 | 06:15 AM
webstir's Avatar
I am just wondering if you still have the H&R race springs for sale or not. IF you could e-mail me at webstir@excite.com with a response that would be very helpful. Thanx
CtheW0rld
Audi A5 / S5 / RS5 (B9)
30
Jul 11, 2019 07:46 AM
ModifiedA4
19
Jun 15, 2006 07:14 AM
EdLove
Oct 5, 2004 06:46 PM
Austin Bluffs
24
Feb 18, 2002 08:12 PM
scooterman
May 12, 2000 10:54 PM
