Water Leak and Interior Damage--HELP!!
Old May 22, 2003 | 05:22 AM
Gator Smiles's Avatar
Default Water Leak and Interior Damage--HELP!!
<center><img src="http://pictureposter.audiworld.com/8610/water_damage_1.jpg"></center><p>After washing today, I noticed some "high water marks" on my interior directly behind the rear most side window (C-pillar?). On inspection, I found a few areas were wet from the recent washing. I imagine I have a pretty good leak at the top of the passenger side rear window. What to do?
Default More Pictures
<center><img src="http://pictureposter.audiworld.com/8610/water_damage_entry.jpg"></center><p>
Old May 22, 2003 | 05:24 AM
<center><img src="http://pictureposter.audiworld.com/8610/water_damage_from_outside.jpg"></center><p>
Old May 22, 2003 | 06:01 AM
saabSean's Avatar
Default Re: Water Leak and Interior Damage--HELP!!
Eeek. Did you use a high pressue washer, or was that from a normal exterior water hose? If it's from a normal pressure hose, I'd say get it to a glass shop for some sealant. If the car is still under warranty, get it to the dealer.
To clean up the water stains, try a good fabric cleaner.
Old May 22, 2003 | 06:07 AM
Default Normal Exterior Water hose
Now under extended warranty.
Old May 22, 2003 | 06:14 AM
Jon C's Avatar
Elder Member
Default this may be a prime example of the limitations of extended "warranties"...
most of which are not "warranties" legally at all, but service contracts.
Check your contract carefully, it may or may not cover things like seals around windows: most do not cover this kind of thing.
Good luck,
Jon
Old May 22, 2003 | 06:52 AM
saabSean's Avatar
Default Re: Normal Exterior Water hose
Sounds like you've got yourself a breach in the window seal. I'd take it to a local glass shop before it rains.
TL12vA4
Jan 20, 2011 07:55 PM
awdinut
Jun 16, 2008 03:59 AM
smootha
May 21, 2007 05:05 PM
laxman1100
Jul 25, 2005 04:09 AM
Critter
Jul 22, 2002 08:22 PM
