What exactly is done with the window tracks
Old May 22, 2003 | 09:15 PM
icaruS4's Avatar
Default What exactly is done with the window tracks
in the "LQ" recall? I'm curious if my dealer screwed up something. Whenever it rains my drivers window will go up part way and then roll back down some when I want it to go all the way up. Only after I had the recall done and only when it's wet out. Any info would be appreciated.Thanks.
Old May 23, 2003 | 05:18 AM
TXurS6's Avatar
Default They may need to be lubed...
They should have replaced the window guides as a part of the recall. My window was doing the same thing as yours. My service rep took some WD-40 and sprayed it inside the door frame grooves where the glass slides. He used the nozzle attachment to get a little spray inside that crease on the back of the door fram where the window slides. It helped immensely.
Old May 23, 2003 | 06:05 AM
TTS_4_to_A6's Avatar
Default There may be a broken clip
Had that on mine twice and the dealer had to replace the tracks and window clips.
Old May 23, 2003 | 07:34 AM
dejavu's Avatar
Senior Member
Dealer changed the tracks, no get them to lube it.
wpatton2@cox.net
Jan 4, 2015 09:27 AM
Audeye A6
Jan 23, 2007 08:18 PM
dirTTlvr
May 30, 2003 11:35 AM
PeterH
May 14, 2002 03:38 PM
