Exhaust tipes!!! Wan't my exhaust to show on my 2000 2.7t, but only like the cut valence HELP Ideas!
Old May 22, 2003 | 09:40 PM
Trigger2.7T's Avatar
New Member
Default Exhaust tipes!!! Wan't my exhaust to show on my 2000 2.7t, but only like the cut valence HELP Ideas!
i need something cheap(less than $500) Can i cut the valence and the muffler and weld exstesions on to it. is this possible. can i bend the muffler,extend it, and cut the valence. If so is cuting the valence hard. Sorry if i seem confused, i just need help.
Old May 22, 2003 | 09:47 PM
Stoney's Avatar
Tech Guru
Default Try these...
<a href="https://forums.audiworld.com/a6/msgs/238709.phtml">Installed 2002 S6 exhaust parts on a 2001 2.7T</a>&lt;br&gt;
<a href="https://forums.audiworld.com/a6/msgs/201965.phtml">Supersprint exhaust through valence of 2000 2.7T</a>&lt;br&gt;
<a href="https://forums.audiworld.com/a6/msgs/199789.phtml">2002 rear bumper/exhausts and painted valence on a 2001 2.7T</a>&lt;br&gt;
<a href="https://forums.audiworld.com/a6/msgs/184784.phtml">LLTek exhaust with rear valence bezels</a>&lt;br&gt;
<a href="https://forums.audiworld.com/a6/msgs/95175.phtml">A6 4.2 installing 02 rear valance on 01, new exhaust too</a>&lt;br&gt;
<a href="http://www.lltek.com/a6_27_42_exhaust.htm">LLTEK Motorsports Audi A6 Valance Through Exhaust Systems</a>&lt;br&gt;
Make sure to browse each entire thread.
They are from the FAQ:<ul><li><a href="http://www.netwiz.net/~jds/files/a6_links.html#exhaust">http://www.netwiz.net/~jds/files/a6_links.html#exhaust</a</li></ul>
Old May 22, 2003 | 09:51 PM
Singletrack's Avatar
Default You can cut the valence with a dremel, buy tips for $20 to $70ea, and have them installed for about
$20. The outlet from the muffler is 2 1/4" if I'm not mistaken, but a decent shop should be able to adapt a different size tip. Here is the link to the ones I just picked up. Good build quality, and you can't beat $12 a piece.
-st<ul><li><a href="http://www.thehitchshop.com/cart/cgi-bin/Html/Products/et_stainless_tips.htm">I got the 005s.</a></li></ul>
Old May 22, 2003 | 10:07 PM
New Member
But the mufflers bend down i want them to go straight out
Old May 22, 2003 | 10:11 PM
Default They just have to cut the downturn tips off, and then weld on new tips. Actually if there is enough
room left after the downturns you might even be able to use some bolt-on tips.
-st
Old May 22, 2003 | 10:13 PM
New Member
Thanks!!!!
Old May 22, 2003 | 10:32 PM
Glad I could help - also check out Stoney's links - always a good place for info.
Old May 23, 2003 | 10:31 AM
jatava's Avatar
Default You can try these...
<center><img src="http://pictureposter.audiworld.com/10982/i-2.jpg"></center><p>You don't have to cut the bumper, these come out right underneath.
 Pouria Savadkouei
 Michael S. Palmer
adrianreece
12
Mar 20, 2023 09:42 AM
ollyjs
Jan 24, 2018 09:34 AM
jhynesrockmtn
Pacific Northwest Discussion
Oct 28, 2003 07:40 PM
bud4ya
16
Jul 25, 2003 11:26 AM
Ming 2.7T
Jun 15, 2001 06:30 AM
