Has anyone used a Gtech Pro and if so, are they accurate?
Old May 23, 2003 | 07:02 PM
Audi Awe's Avatar
New Member
Default Has anyone used a Gtech Pro and if so, are they accurate?
For info see this site.
http://www.gtechpro.com/
Old May 23, 2003 | 07:08 PM
Haystack's Avatar
Default Yes, and pretty good!
It is very consistent, which is what I was looking for -- a way to compare things under reasonably standard conditions.
I have not tested it on a track, but have used it a fair amount on the road.
Old May 24, 2003 | 05:35 AM
Audi Awe's Avatar
New Member
Default Re: Yes, and pretty good!
Thanks!
Old May 24, 2003 | 08:33 AM
Hy Octane's Avatar
Default About your RS6 trunk lid spoiler..
I just got mine from Josh at Achtuning in the fedex mail this am.. Did you keep the bolts or did you cut them off? Any problems with mounting? Thanx..
Old May 25, 2003 | 09:14 AM
Audi Awe's Avatar
New Member
Default Re: RS6 Spoiler and bolts.
I kept the bolts on. It takes some courage to take a drill to your car but I thought it would be the best install over tape.
I used two-inch masking tape on each end of the trunk, and where each of the 4 bolts would line up. (approximately) Since I did it myself, held the spoiler to one side of the trunk, measured carefully, and split the total, which gave me equal distance on both sides. Then pressed gently on the tape. U want to make sure u line your spoiler up approximately with the tops of the rear tail lights.
This left indentations on the tape which I then drilled out. Rubber gaskets on the outside, a little caulk and your good to go.
Had to remove the trunk liner, 10 snaps, two hidden screws in the lining, (on each end) and removed the two trunk handles. Bought bolts at hardware store.
Start to finish 1 hour.
Good luck
Hope that helps.
Old May 25, 2003 | 11:19 AM
Hy Octane's Avatar
Rodger.. Thanks for the info.. !!
mbigos
Sep 14, 2013 02:46 AM
rd350
Apr 2, 2006 03:42 PM
HugeTTs
10
Feb 15, 2006 09:16 AM
BJcurby
Aug 4, 2003 06:31 PM
Scott Massey
Jul 14, 2001 03:24 PM
