First Impressions - 605 Relay Pulled
Old May 25, 2003 | 10:21 AM
dlubin's Avatar
New Member
Default First Impressions - 605 Relay Pulled
After getting past the V1 saga, I decided that the next big item I wanted to try to address was the 'lincoln town car' steering that was driving me nuts.
So, I printed off the instructions from the tech section and went to work! Removing the relay went well, though at 6'3 I don't have "small hands" and really had to wedge my hand under the dash to get the relay out. I immediately labeled 'up' in case I want to put it back.
First impression is that the steering is a LOT heavier, in fact, heavier than my BMW (which still has a week to go in the lease). If I had to compare it to another vehicle I was familar with, it'd be similar to low-speed steering in the BMW X5. At high speeds I also perceive higher steering effort, but that may just be me.
All in all, I prefer the heavier feel, but think the 'solution' is somewhere in the middle - low speed maneuvers are a little rough without the relay in place.
As mentioned in the FAQ, it didn't cause any errors or warning lights, the only thing I noticed was a 'groan' in the steering at times, but that may have been my imagination.
I'll be driving my bimmer and the audi back and forth over the course of the week and will try to do some more comparison.
-Dan
Old May 25, 2003 | 10:54 AM
2.7tDallas's Avatar
AudiWorld Expert
My groan was a bad tie rod end, and somewhat worn tires
Old May 25, 2003 | 10:57 AM
BlackA6's Avatar
New Member
Hi Dallas, how do you like your Hyperboost DV's?
Old May 25, 2003 | 11:01 AM
2.7tDallas's Avatar
AudiWorld Expert
Default Really great! I had the 710's stock on the 2003, and they were ok, though one was going bad
smoother shifting, cured my rough idle
Old May 25, 2003 | 02:30 PM
Mike4.2CBW's Avatar
Junior Member
Default Could always switch it on for low-speed and off again for high...
<ul><li><a href="https://www.audiworld.com/tech/elec35.shtml">Switchable Servotronic</a></li></ul>
Old May 25, 2003 | 02:46 PM
TXurS6's Avatar
Give it a week. You will get used to it without the relay.
Old May 25, 2003 | 06:08 PM
dlubin's Avatar
New Member
True, but not that motivated &lt;g&gt;
weinerj100
S4 (B8 Platform) Discussion
17
Apr 1, 2010 11:27 AM
Brdman*
Audi 100 / A6 (C4 Platform)
Apr 3, 2005 06:23 PM
ar5154
Audi allroad
16
Mar 22, 2005 01:35 PM
isi0410
May 22, 2003 10:09 AM
