oil change help 99 a6
The rectangular pan with a allen wrench plug apparently is not engine oil ... my guess is that its oil for the differential, grey looking liquid that looks rather watery compared to engine oil.
Big question .. how do I put it back? where is the filler valve?
And I did find the real oil pan ...
art
oh yea, it is a quattro
I am not sure, but sounds like you may have just drained your transmission fluid, which at $9 per quart x 8 quarts, will be expensive to replace. I think your car is likely going to need to be flatbedded to the nearest dealer.
First - Confirm you're a 2.8 tip. If so, I've done a tranny service on that set-up. <a href="https://forums.audiworld.com/a6/msgs/238621.phtml">Here's a link to some links</a> with more info than you probably want to digest right now. There are some pictures of the bottom of the car with the tranny pan removed, which you should be able to use to tell if that's the area from which you removed the drain plug. From your description, it seems likely.
Second - The ZF trannys are very picky about ATF level, and do not have a top fill. You fill the tranny through a raised hole in the tranny pan, at a time when the tranny fluid is in a defined temperature range. You measure this range with a VAG tool (dealer computer analysis set up) or a VAG-COM, which is a VAG tool emulator running on a laptop.
If you want to talk, email me and I'll send you my phone number. Click on my username in the post header above for my email.
Art
