Door hitch squeak (A6 Quattro)
Old May 26, 2003 | 05:50 PM
JimK's Avatar
Default Door hitch squeak (A6 Quattro)
Recently, the suqeak noise come out when the front door open or close.
Does anyone know which kind of lubricant spread apply to eliminate the noise?
Old May 26, 2003 | 06:59 PM
mbr's Avatar
mbr
Default Re: Door hitch squeak (A6 Quattro)
You can use any lubricant (WD-40, silicon spray, etc), but the best, long-term solution is a small dab of axle grease to the hinge. The thinner oil-based sprays will work, but only for a few months.
Old May 27, 2003 | 03:25 PM
technokid's Avatar
Junior Member
Default White lithium grease works better than wd40 as a lubricant
at least thats my experience. I feel as if wd40 is more of a "cleaner" or solvent...you can maybe use the wd40 to clean it first than use the white lithium.
hptaxis
Dec 16, 2017 08:22 AM
ichibunz
NY / NJ / CT Discussion
Feb 10, 2009 01:34 PM
RickS
A4 (B7 Platform) Discussion
Apr 22, 2007 07:28 PM
UR-Idiot Savant-S6
17
Sep 5, 2002 06:27 PM
Dallasaudi
Misc. Models Discussion
Jan 10, 2001 01:30 AM
