Spacer on Quattro
Old May 28, 2003 | 02:16 AM
Petterjacobsen's Avatar
New Member
Default Spacer on Quattro
Will the Quattro system be damaged if i put on 20mm spacers in the back and 10mm in the front?
(I dont think so, but I have to ask...)
Who has some good spacers?
Old May 28, 2003 | 04:54 AM
fvike's Avatar
Default Re: Spacer on Quattro
Wouldn't think so, the Quattro system is sensitive to roll diameter on the wheels, with different spacers, I don't think one wheel would roll any longer or shorter than other wheels on the car. As long as the wheels got the same dimmesion all around the car, you should be OK.
Old May 28, 2003 | 07:29 AM
Dan_L's Avatar
Junior Member
The rear track is already wider than the front. It shouldn't cause any problems.
Old May 28, 2003 | 07:34 AM
New Member
I had to ask. Just to be on the safe side...
Bye the way! I am getting the lower plastic on my car painted on monday! A guy on Gulskogen in Drammen whould do it for 2500kr. The other painter wanted 4500kr...
Old May 28, 2003 | 07:36 AM
New Member
Default Re: The rear track is already wider than the front. It shouldn't cause any problems.
Is it wider in the rear? It is in the rear I need spacers...
Old May 28, 2003 | 08:07 AM
AUJ's Avatar
AUJ
Default No. Make sure they are hubcentric and lipped to curb associated vibration issues. This pic is my
<center><img src="http://pictureposter.audiworld.com/46293/auja6sig.jpg"></center><p>
old '01 with 20 in back and 5 is front.
Old May 28, 2003 | 08:42 AM
New Member
Default Re: No. Make sure they are hubcentric and lipped to curb associated vibration issues. This pic is
<center><img src="http://www.hr-spezialfedern.de/images/spurverbreiterungen/HG_Distanzringe%20neu.jpg"></center><p>I an thinking of this:
20mm back, 10mm front.
Old May 28, 2003 | 09:47 AM
AUJ's Avatar
AUJ
Should be fine.
 Pouria Savadkouei
 Michael S. Palmer
jimmys2.8
Jul 6, 2010 10:53 AM
BosphorusS5
Sep 11, 2009 09:24 AM
|everso!|
15
Nov 29, 2007 03:09 PM
ashwins
Jun 13, 2005 07:29 AM
$teady$upreme
May 30, 2003 10:05 AM
