Sucking noise(no pun, really) on start up, mech says........
Old May 28, 2003 | 07:42 AM
youngspeed's Avatar
Default Sucking noise(no pun, really) on start up, mech says........
.....its a vacuum pump drawing warm air to heat up the brake lines. Any truth to this. Anyone with their 2 cents pls...
Old May 28, 2003 | 07:50 AM
Muhammad's Avatar
Default Mine was doing the same, but it was the line itself, not the pump...
Follow the line from the brake booster and see if you can find any obvious cracks or leaks.
I did it with the car running, so I could push on the hoses in various places to see if there were any obvious spots. Indeed there were.
If you find the spots, you can use electrical tape as a temporary solution until you replace the hoses (they're fairly cheap).
Old May 28, 2003 | 08:27 AM
PaulW's Avatar
Default Vacuum pump drawing warm air to head up brake lines? Somebody needs a reality check
It's probably your air pump which pumps air into the exhaust, here's some pics from somebody with a 4.2 that recently asked the same questions, these are pics of the A8, but probably the same for your car, BTW, what year is it?
And no, you don't need to warm up brake lines.....I would change mechanics if somebody told me that.
Here's the pictures, it's almost self explanatory. The pump is driven by a motor in the air box
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/ai1.JPG">
The big diaphrams open up and the pump pumps air into the exhaust
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/ai2.JPG">
There is a small solenoid valve that ports vacuum to the top of the big diaphrams
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/ai3.JPG">
The ross-tech tool can test the component, and I've tested them before, and the air pump is quite loud, probably it.
Old May 28, 2003 | 06:31 PM
youngspeed's Avatar
Default Re: Vacuum pump drawing warm air to head up brake lines? Somebody needs a reality check
Brilliant. Thanks! Can anyone say new mech?
Pre95
Aug 14, 2008 02:17 PM
cparke
Jul 6, 2008 12:33 PM
A6AvantErik: MCS
Audi 100 / A6 (C4 Platform)
May 27, 2008 07:30 AM
4Bidden
23
Jan 8, 2006 03:04 PM
delmedina
Nov 16, 2005 08:23 AM
