CD Changer for '00 A6 Avant - HELP
Old May 28, 2003 | 05:38 PM
EQXAvant's Avatar
New Member
Default CD Changer for '00 A6 Avant - HELP
Help- I've searched and searched and can't find all the answers.... I'm facing a 900 mile drive in a couple of weeks and would love to have the changer...
What aftermarket cd changer works (plug and play) with the Premium Bose stereo?
Does the changer fit in the OEM mounting bracket?
Do I need an adaptor cable?
What additional mounting hardware is needed?
Will the changer work with the audio buttons on the steering wheel and the CD buttons on the radio?
Old May 28, 2003 | 11:39 PM
John Simcox's Avatar
25 Year Member
Default Re: CD Changer for '00 A6 Avant - HELP
Audi OEM product is a straight plug and play (cable in the left hand side of the boot). Panasonic CX-DP610 is the basically the same product but you will need to buy an adaptor cable. Sony, as part of their "Sony On Top" range also do a compatible product.
I have seen people mention on th is board that the OEM product can be had for $150 although Clair's have it on their site for $314.95<ul><li><a href="http://www.clairparts.com/accessories4.asp?product_id=1482&amp;PDID=57965">h ttp://www.clairparts.com/accessories4.asp?product_id=1482&amp;PDID=57965</a</li></ul>
Old May 29, 2003 | 05:20 AM
TraderAlex's Avatar
Default I installed the changer from Clair a couple years ago
I, too, have a '00 A6 Avant. My word of advice-forget, and don't even think about aftermarket changers. Only recently on this board, some member cited compatibility issues withe changers they bought. The OEM changer is made for Audi/VW by Panasonic, but at least you can be certain it will work, and fully integrate with all the controls on your head unit. Further, there is a detailed article in the tech section, how to install it-it's roughly 25 minutes' worth of work.
Remove the rear bracket from the left rear compartment, as the writer suggests: it's definitely easier installing the changer with the bracket out of it's box, than in.
absoluTT A3
Nov 9, 2007 05:16 AM
TeddyBGame
Dec 18, 2003 01:14 PM
improved just pino
Nov 19, 2002 12:35 PM
Neil C
Feb 22, 2002 05:18 AM
karter
Apr 12, 2001 12:13 PM
