Anyone know the oil capacity of the 2001 6-spd trans?
Old Dec 7, 2004 | 05:19 AM
mike's01's Avatar
Default Anyone know the oil capacity of the 2001 6-spd trans?
I've searched and can't find any 'official'capacity as published by Audi
Old Dec 7, 2004 | 06:25 AM
john in cincy's Avatar
Junior Member
7 quarts last time I filled it.
Old Dec 7, 2004 | 07:08 AM
mike's01's Avatar
It's a 6 spd trans which I think is <3 qt. not the engine cap.
Old Dec 7, 2004 | 07:45 AM
S4_Cinci (I S'edTFA)'s Avatar
Member
Default You have quattro, correct? 2.9 quart fill (it might be litres). People have said to buy 3 qts for
doing fluid change on tranny/transaxle unit and 1.9 qts for rear differential. I will check the archives now and make sure...I will post confirmation!
Old Dec 7, 2004 | 07:53 AM
Member
Default Look in the Tech section under Misc. A guide for doing transaxle and rear diff will be the 1st two
articles on the list! That says 2.9 quarts for transaxle and 1.9 quarts for rear diff. This Tech section write-up is for an A4, which is the same as an S4 and I'm assuming that the A6 should be the same capacity; (but I wouldn't bet a paycheck on it).
Old Dec 7, 2004 | 08:06 AM
Peccavis's Avatar
Default Depends...
According to Bentley...
Code letters EDU - 2.3 liters.
Code letters EEY and EHS - 3.6 liters (this includes 0.3 liters for transmission oil cooler and lines).
My MY2000 took about 2.1 liters when I changed. I suspect a residual 0.2 liters remained in the tranny. I could be wrong, but I think the EDU tranny was only on MY2000.
Old Dec 7, 2004 | 08:16 AM
Junior Member
Default So does he want to know transmission fluid capacity or ...
engine oil capacity for a 6 speed??
John in Cincy
Old Dec 7, 2004 | 08:55 AM
mike's01's Avatar
Default Transmission capacity... I've got the 'unofficial' fill quan. from the archives.
I've got 3 quarts of Red Line MT 90 and I'm hoping it's enough....
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 7, 2004 | 08:57 AM
Peccavis's Avatar
You should crawl under your car to get the tranny code letters, just to be sure.
Old Dec 7, 2004 | 08:58 AM
Member
Default My assumption was trans fluid or "oil" for the trans since he gave details on the tranny only.
If he would have given engine details, then I would have guessed engine oil capacity. But that is just the way I thing - I figured he knew that engine oil capacity depends only on the actual engine, doesn't matter what tranny is connected as far as I know. Too much brevity leads to unclear communications on this forum! As you can see, brevity was never my strong point! ;-P
