Been wading in the archives for a while - can you all help a 2.7T allroader with a timing belt...
Old Dec 7, 2004 | 08:40 AM
RMcQ's Avatar
Default Been wading in the archives for a while - can you all help a 2.7T allroader with a timing belt...
replacement procedure? Somebody must have written up something of a procedure or tech-article with pics etc. but I can't find one. And yes I checked Stoney's links as well.
Thanks.
Old Dec 7, 2004 | 08:47 AM
gietl's Avatar
Default Re: Been wading in the archives for a while - can you all help a 2.7T allroader with a timing belt..
Here is on on a 1.8T, http://www.clubb5.com/forums/viewtopic.php?t=94757
The misisng images should be at he link below:
I know this isn't a 2.7T but it may help.
EDIT: &lt;ake sure you have a Bentley manual as well, do not even try doing it without one.<ul><li><a href="http://www.rmcb5.com/modules.php?set_albumName=album51&amp;op=modload&a mp;name=Gallery&amp;file=index&amp;include=view_al bum.php">missing pictures</a></li></ul>
Old Dec 7, 2004 | 08:57 AM
RMcQ's Avatar
Default Thanks! I know there has to be a similar write up somewher for the 2.7T.
and yes i will be armed with Bentley, ETKA, VAG-COM and everything else that I have in the garage.
Old Dec 7, 2004 | 09:39 AM
por911's Avatar
Default timing belt help...
You can use the V6 write ups in the tech section. I would get a bentley CD. Worth it for torque specs and factory tool #'s. I believe the tools I have are the same for 2.7T (tools 3242,3212,3391). Check the manual though, it may be one of the T#'s for the cam bar.
Old Dec 7, 2004 | 11:58 AM
dan farmer's Avatar
Senior Member
Default there's a write-up for the 2.8 NA motor...
<ul><li><a href="https://www.audiworld.com/tech/eng39.shtml">not a 2.7 or an allroad, but...</a></li></ul>
Old Dec 7, 2004 | 01:32 PM
jasaab's Avatar
Member
Default Get the Bentley CD
If you plan on doing any work on your car a must is a vag.com software and a Bentley CD manual. I have done everthing from timing belts to total supension repairs and cam adjuster seals with these manual.
Old Dec 7, 2004 | 05:35 PM
RMcQ's Avatar
Default Bently, check. VAG-COM, check. ETKA, check.
I have it all and could probably proceed on my own, but sometimes there are real world tips/tricks/hints that come across in communities like AW that are not conveyed by a shop manual.
Old Dec 7, 2004 | 05:36 PM
RMcQ's Avatar
Default That's the second good one I found for hte 2.8. I guess there are many similarities.
probably more than the differences. Thanks for the link.
 Pouria Savadkouei
 Michael S. Palmer
baubau2.7
9
Dec 14, 2009 03:07 PM
Samouce
Aug 8, 2007 05:37 PM
Canon
Jan 16, 2007 07:37 PM
Ming rings in Minn
14
May 21, 2004 10:50 AM
