Update on Tiptronic failure...and paging TeddyBGame!!!
Old Dec 8, 2004 | 06:14 PM
Boston Driver's Avatar
AudiWorld Expert
Default Update on Tiptronic failure...and paging TeddyBGame!!!
I checked the magnet in the shifter, and it is intact in the rubber housing. However, I noticed this afternoon that my autodimming mirrors were not operating. Noticed also that the compass mirror was not operating as well. Seemed odd, checked the fuse (#31) and it was blown.
Checked the manual and this is the same fuse that runs the backup lights, cruise control, autodimming mirrors, data link connector for On Board Diagnostics, and automatic transmission.
So I replaced the fuse, turned the key on to see if the compass mirror operates, and it did not. Checked the fuse, blown again.
Any ideas on what is causing this short? I did the Passport Hardwire late last week, but tapped power into the heated mirror fuse (#9), nothing to do with the autodim. Also, the Passport is working just fine.
Any other thoughts??? If I pull the dash again, what should I look for down there?
On a side note, I noticed in a search for "Fuse 31" that TeddyBGame had the same issue last year. Ted, what was the resolution of your tiptronic issue???
Old Dec 8, 2004 | 07:12 PM
Silver A6Dude's Avatar
New Member
You have a short someplace. Start unplugging one at a time - see where you end up.
Old Dec 9, 2004 | 01:01 AM
New Member
Those are there, but under accessories, not electrical - I guess since they are optional add-ons?!?
Old Dec 9, 2004 | 05:31 AM
PaulW's Avatar
Agreed, need a multimeter and some time plus a schematic
Old Dec 9, 2004 | 05:48 AM
TeddyBGame's Avatar
Default email sent...
I used a blade style fuse tap on #31 (I think) and it pushed the connector back inside the fuse box. Because of this...my tiptronic would engage...nor would my reverse lights come on.
At some point, I need to pull off the back of my fusebox panel and push it back into place.
Never again...will I use those fuse taps!!!!! I was so pissed off.
-ted
cheeks
Q7 MK 1 Discussion
Jan 23, 2020 01:30 AM
cheeks
Q7 MK 1 Discussion
Oct 27, 2015 05:58 PM
Beau Matthews
Q7 MK 1 Discussion
Aug 8, 2015 04:44 PM
DamienH
Audi A3 / S3 / RS 3
Nov 9, 2005 04:15 PM
M0W0G
Dec 3, 2001 09:03 AM
