Secondary Injection Pump
TIA
The air pump dilutes the air during the initial minute or so, while the cats are warming up.
This pump is triggered by selenoid, which in turn is triggered by your vaccum line. These vaccumm lines rupture frequently & the air pump never turns on...triggering the CEL.
Double check that "loose pipe" again. Check all vaccum lines to and from the air pump selenoid.
Good luck.
I just replaced rivets with small screws/ lock nuts. Another person simply used zip strips since it's a plastic housing and that worked fine too.
17536: Bank1, System too lean
17538: Bank2, System too lean
17822: Sec Air Inj Sys, Bank2 Leak Detected
17832: Sec Air Inj Sys, Bank1 Leak Detected
Without knowing which VAG Code the CEL is showing, your problem could be one or more of several items.
