Tires...will these fit?
Old Dec 9, 2004 | 02:27 PM
Press's Avatar
Fear the Miata!
Default Tires...will these fit?
255 40ZR 17 Conti Extremes on an '02 2.7T?
Any rubbing issues? Or any other issues I need to know about....
Old Dec 9, 2004 | 02:28 PM
Kimchee's Avatar
Member
yes they will... unless the 2.7T that it's going on is SLAMMED.
Old Dec 9, 2004 | 06:36 PM
Boston Driver's Avatar
AudiWorld Expert
Default just make sure you have >10mm clearance now...
between the inner wall of your 235 tire and the upper arm of the strut assembly. It overhangs the inside of the wheel/tire at about 12 o'clock. If you can stick a finger between the inner wall of the tire and the strut assembly, then you should be okay.
dragls
Wheels & Tires Discussion
May 18, 2009 06:43 AM
4tt
Aug 17, 2002 10:33 AM
pwaug
Jun 5, 2001 08:10 AM
Mancubus
Aug 15, 2000 10:40 AM
racer
Oct 22, 1999 11:19 AM
