Anyone tell me how to remove the back seat, top portion????
Old Dec 10, 2004 | 07:55 AM
Kgnast-Nemo4.2's Avatar
Default Anyone tell me how to remove the back seat, top portion????
I have to do a seat swap. Front and rears.
Old Dec 10, 2004 | 08:03 AM
Boston Driver's Avatar
AudiWorld Expert
Default Fold seat down, you should see a hinge between the two sides...<EDITED!!!>
that is fastened to the body. There is a cover whhich is removed by pulling up from the reaward side and rotating forward. This will expose a bolt for the metal plate that holds down the "hinge-pins" for the seat backs. Take the bolt out, and you should be able to remove the seat backs. Takes a bit of squishing around to get to the hinge.
Side bolsters are a bit more tricky...
They are held in by long pins from the side near the top that have to be removed. There is a nut that needs to be loosened, then the pin can be removed. There is also a retaining clips that holds in the bottom of the side bolster.
Hope this helps. Shoot me an e-mail if you need the actual Bentley diagrams.
Good luck!!!
Old Dec 10, 2004 | 08:04 AM
Please do chime in as I'm snagging some beige sport seats baby!!!!
AudiWorld Expert
Default I am assuming you have the link to the front seat swap?
if not, just click on my sig and look for the link to the sport seat install. What seats did you get???
Old Dec 10, 2004 | 08:05 AM
AudiWorld Expert
Default Wow, you and ultrarunner in the last two days!
what sort of trend have I started???
Old Dec 10, 2004 | 08:08 AM
lol, well, we finally found beige sport seats - which are a friggin rarity around these parts.
Old Dec 10, 2004 | 09:02 AM
AudiWorld Expert
Default When you do the rear swap, be sure to snap some pics...
do a writeup for the forum. Damn, you guys beat me to fronts and rears. I am still trying to work out something with the rear sports.
Old Dec 10, 2004 | 04:59 PM
AudiWorld Expert
See the edited post above^^^^^^^^^^^^^^^^^
 Pouria Savadkouei
 Michael S. Palmer
WhteA4Turbo
Nov 12, 2004 05:09 AM
1.8Steve
Apr 2, 2003 09:26 AM
VTstage3a4
Nov 7, 2002 02:39 PM
1FASTT
Nov 14, 2001 02:26 AM
Liquid
Sep 14, 2001 01:38 PM
