battery life
Old Dec 10, 2004 | 03:51 PM
dweinman's Avatar
New Member
Default battery life
Any estimates on how long the average original battery lasts on A6 4.2?
Old Dec 10, 2004 | 04:10 PM
6ULDV8's Avatar
Junior Member
Default On the average about 4 years. I have seen them last
as little as 2 years and as long as 7.
Old Dec 10, 2004 | 04:13 PM
GBW's Avatar
GBW
Default Re: On the average about 4 years. I have seen them last
Four years is the longest I've seen. 17 years of experience with VW/Audi batteries. Make sure you keep the water level where it belongs....dealer never checks it, although it is part of the service. I've seen it dry on two occasions when I get too lazy to check. I'd check every six months.
Old Dec 10, 2004 | 05:11 PM
6ULDV8's Avatar
Junior Member
Default Batteries that can be filled are ancient relics. Todays battery is a non service
item. You cant check the water without cracking the case open.
Old Dec 10, 2004 | 05:14 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Both my '99s had fillable factory batteries. They lasted until Fall 2003, or around 5 years.
Old Dec 10, 2004 | 05:18 PM
GBW's Avatar
GBW
Default Re: Both my '99s had fillable factory batteries. They lasted until Fall 2003, or around 5 years.
In October I shamed the dealer into replacing the battery at their expense....battery was bone dry 3 days after 50,000 mile tune up. Second time I'd been stuck, it's happened to my father also.
As of October 2004, Audi is still using batteries you have to add water to in the A4 and A6 models. Granted, my 1968 Buick is truly non service, but that is not what the dealers are using.
Old Dec 10, 2004 | 05:41 PM
6ULDV8's Avatar
Junior Member
Default Sigh..... Yes, you can pry the bar/cap off the top of the battery
to check the water level but you have to work at it to do so. The days of the little screw caps for each cell are gone. You can put water in them if your so inclined but from Audi service schedule they are a non service item. I have not seen a tech check battery water levels in years. Granted you can squeeze some extra life out of them by doing so, but its just not routinely done anymore.
Old Dec 10, 2004 | 05:44 PM
jbchinoca's Avatar
Default Mine just quit
Five years in my case. Of course the timing was perfect, all loade up to go to my mom's for Thanksgiving dinner. AAA showed up in a record 10 minutes. My local Kragen just happened to still be open, had my battery, so I changed it at my mom's b 4 dinner.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 10, 2004 | 05:49 PM
GBW's Avatar
GBW
Default Sigh, no need to pry, the factory battery still has screw caps!
You can get some extra time on them by keeping the levels up, but after 4 years, just bite the bullet and replace it. It's not worth getting stuck. The dealer didn't argue on the replacement, they knew it is part of the service.
Old Dec 10, 2004 | 05:56 PM
R2.7TA6's Avatar
Member
Default Re: battery life
R's was replaced in R '01 2.7T under warrenty this past week. They tested it and declared it marginal, no questions asked. 3 yrs old.
