Turn signal flasher unit location?...
Today, my turn signals stopped working. When I flick the right (or left) turn signal, the indicator lights, both outside and 'arrow' on gauge cluster, turn on once or twice & die!
The hazard switch and flashers work just fine. I am guessing that there are 2 seperate flasher units, one for the turn signal switch and one for the hazard switch. Checked the fuse (position 2, 10amp) and its just fine.
Where in my car is the "flasher unit" for the turn signals located? Any thoughts on what else could cause this?
Thanks.
Be sure to not lose the cable that it's connected to. if you do that you're in trouble.
It's about $25-$30 and took me about 15 mins to get the old switch out (but would take less time if doing it a second time).
Search the A6/S6 forum for "hazard switch" or "hazard relay" and you'll find instructions.
Since the hazards switch and flashers are working fine, I was of the impression that this is a seperate relay/flasher-unit, specifically, for the turn signals.
Thanks.
What's the trick to remove it?
1. Pull 2 metal clips out and remove the cup holder
2. Remove blank button (=cover)
3. Thru the opennings on both sides, squeeze and pull hazard switch out (may need help of tiny fingers owner)
P.S. ! indicate metal clips that apparently you broke off the trim piece. Pull them and glue back to the trim piece before installation.
