Won't Start ....
Old Dec 12, 2004 | 03:32 PM
JPZ's Avatar
JPZ
New Member
Default Won't Start ....
I just had the throttle body recall done Friday (98 2.8Q). Tonight it just cranks over and over, tries to fire on about 2 cylinders, but won't start. Always started perfectly before.
Any thoughts on the cause?
Thanks.
Old Dec 12, 2004 | 03:50 PM
Ritz's Avatar
Any spark? VAG scan?
Old Dec 12, 2004 | 04:57 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Precisely why I will not go in for the TB recall.
Sounds like something was not put back correctly or came apart. The question is: when you take it back to the dealer will they diagnose it as something TB related or some random problem that just happened to crop up right after the TB recall.
Old Dec 12, 2004 | 05:32 PM
JPZ's Avatar
JPZ
New Member
Default Re: Update TB recall
Well, the TB recall including some breather hose supposedly also fixes the "leaks oil in the winter but not in the summer problem", if you live in a cold climate. So we will find out about that soon. Anyway, I went back out and cranked hard for about 60 seconds straight, she started rough and then seemed to run fine and restart again after that. The cruise control doesn't work right either. So back to the finest Audi dealer in Nebraska we will go.
Old Dec 12, 2004 | 06:11 PM
kxdad615's Avatar
New Member
JPZ were at in Nebraska??
Old Dec 14, 2004 | 06:17 PM
JPZ's Avatar
JPZ
New Member
Default Re: JPZ were at in Nebraska??
I'm in Omaha. You here too?
Tom Faust
Mar 27, 2005 03:39 PM
85-4kq-girl
Oct 26, 2004 09:41 AM
jwind
May 23, 2004 03:32 PM
birdmanmt
Sep 2, 2003 06:59 PM
vaporhat
Dec 19, 2002 07:00 AM
