how hard are rear brakes to change?
Harbor Freight has an inexpensive tool, or you can usually rent them from the local Autozone.
Otherwise no other special tools are required. It's a straightforward remove and replace.
Also, the manual says the rear caliper bolts are one time use, and you should use new ones for each replacement. I have not replaced them.
