Clunk going over bumps
Old Sep 10, 2005 | 12:02 PM
nasdaqer's Avatar
New Member
Default Clunk going over bumps
Hi all -- new to the board. Just bought a 2000 A6 2.8 FWD (not quattro,, next time...) with 98k on it for $8,800. Its excellent cond with the exception of some missing/dead pixels and a small clunk when I go over large bumps or potholes. The sound is coming from the front driver's side. Sounds like from right under the dead pedal area.
I've owned more Honda Accords than I care to remember and it doesn't sound like the CV joints, like it did on the old Accords. It makes no clicking sounds when I turn, etc.
Any thoughts?
Thanks all, glad to be a part of the board!
Old Sep 10, 2005 | 02:08 PM
Ritz's Avatar
Most likely one of the control arms.
Old Sep 10, 2005 | 02:10 PM
muzzy996's Avatar
Default Have the control arms checked, tie rod ends and sway bar end links.
On my 98 A6Q w/ 83k miles that I recently picked up the dealer replaced the tie rod ends suspecting that they would fix the problem (ends were worn) but it didn't.
Their next suggestion was the sway bar end links but since that isn't covered under recall I did it myself (quite easy and cheap at $60 for the parts).
What I found was that simply inspecting the end links isn't good enough. Even if the boots around the link bolts are still good the inside could be worn and you wouldn't know it. The stock ones on mine looked fine and as I moved them around it was easy to move but there was no apparent play that I thought would cause a clunk. I replaced them anyhow since the parts were paid for and the clunk was gone.
Old Sep 10, 2005 | 02:45 PM
nasdaqer's Avatar
New Member
Default Re: Most likely one of the control arms.
I haven't even priced control arms -- how much is that gonna cost? Any one else have any other thoughts?
Old Sep 10, 2005 | 04:16 PM
Ritz's Avatar
You can get all 8 and tie rods with new bolts from ECS for $500 and change.
Old Sep 10, 2005 | 05:15 PM
nasdaqer's Avatar
New Member
Default Re: You can get all 8 and tie rods with new bolts from ECS for $500 and change.
hmm, thats not too bad. This stuff adds up fast, though. I'm going to do all four brakes, since it feels like they are warped. 500 here, 500 there... Plus the Vagcom OBDTool for the check engine light....
Do you have the ECS website? www.ecs.com is some computer hardware site.
Old Sep 10, 2005 | 07:04 PM
por911's Avatar
Default Check the driveline mounts(ala- trans, motor, diff)....
If you remove the belly pan under the car, look to the right and left under the motor mounts for a blackish-purple fluid. If you see it, then its time for new.
Like the others have mentioned, Audis like front end components, so its worth a look.
Old Sep 11, 2005 | 08:59 AM
JoeVane's Avatar
www.ecstuning.com
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 11, 2005 | 07:42 PM
meq123's Avatar
Default Yep. Had the same symptom and mine was control arms. See this...
Debugging suggestion:<ul><li><a href="https://forums.audiworld.com/a6/msgs/510214.phtml">https://forums.audiworld.com/a6/msgs/510214.phtml</a></li></ul>
Old Sep 12, 2005 | 05:20 PM
nasdaqer's Avatar
New Member
Default Re: www.ecstuning.com
thanks mang
cameltrophyallroad
Audi allroad
Jan 2, 2009 08:18 AM
iProDrive
28
Nov 1, 2006 10:23 AM
trops
9
Nov 20, 2005 07:36 AM
cdnA4
Jun 24, 2005 07:06 AM
ADAZZ
Audi 100 / A6 (C4 Platform)
Sep 1, 2004 07:27 AM
