Brake fluid change with ESP
Old Sep 10, 2005 | 06:41 PM
RazeA6's Avatar
Default Brake fluid change with ESP
I am thinking of doing this myself. I have a 2000 4.2 with ESP (no jokes please). Bentley says to run the ESP pump using a Vagcom prior to bleeding. Just wanted to check - what does everyone else do on this board that have ESP systems. Is this necessary or can you just bleed the brakes normally or do I just take it to the stealer. By the way I did read read Paul W's fine tech article but there is no mention of ESP.
Old Sep 10, 2005 | 07:05 PM
Press's Avatar
Fear the Miata!
Default I haven't used the VAG when I changed the brake fluid......
don't think it makes a difference....and my car has ESPn...as I call it...8^)
Old Sep 10, 2005 | 08:10 PM
Fairfax 4.0T's Avatar
Default I never cycle the ABS pump with VAG-COM when changing.
There is a page on the Ross-Tech VAG-COM site that says the only time you need to cycle the ABS pump is if you get air in the system.
If you don't screw up and let the brake reservoir run dry, then you should not have to cycle the pump.
Old Sep 11, 2005 | 09:12 AM
RazeA6's Avatar
Default DHPress - do you have a brake bleeder or do you use the pedal pump method? I live in Chicagoland and
looking for assistance if anyone would like a case of thier favorite brew!
Old Sep 11, 2005 | 08:45 PM
Press's Avatar
Fear the Miata!
I don't have a bleeder but can get access to one....I'll send you an email....
Old Sep 12, 2005 | 05:46 AM
JAA 4.2's Avatar
Just bleed the brakes as normal. The HU only holds a couple cc's of fluid.
JL TT
VAG-COM Discussion
Jul 31, 2007 01:21 PM
aca
May 3, 2006 01:06 PM
dvandentop
26
Jan 3, 2004 10:09 AM
M0W0G
Motorsport Discussion
Aug 29, 2001 08:44 AM
ryans4
Jul 16, 2001 11:32 AM
