Last week my ESP& ABS light keep coming on, so I scheduled an inspection at the local dealer. A
Am I correct in assuming they just ripped out an interior panel to get to the switch area? It's still under warranty so they'll fix it either way. But, I like to know if it just pulled apart(highly doubtful IMO) or is shoddy work by a gorilla technicians.
<img src="http://pictureposter.audiworld.com/47246/picture_242.jpg">
<img src="http://pictureposter.audiworld.com/47246/picture_239.jpg">
If there's any real problem, you'll see it there. They may have left those screws out allowing the lower panel to hang down.
To fix your problem here, loosen the bolts under the steering column trim and the fuse box, push the panel up with the palms of your hands. The panel should "lock" in place without you needing to hold it up to secure the bolts.
Install tip for the one by the fuse box: If you do not have a good magnetic socket, use some electrical tape to secure the bolt into the socket you are using so it will not fall out.
If you look at the left side of this pictrue from my steering wheel installation, you can see the upper edge of the lower dash panel. The first "nub" from the right edge of the panel is like a hhok that locks the panel into place when installed properly. The one just to the left of the nub is the tab that bolts to the dash under the steering wheel trim!
If that is broken, the WHOLE trim panel has to be replaced. If they broke it, they should replace it!
<img src="http://home.earthlink.net/~oxy8384/images/bill/photo/Audi/605mod/column_bolts.jpg"><ul><li><a href="http://home.earthlink.net/~oxy8384/605mod.htm">link to more pictures of the dash panel removal</a></li></ul>
