Sucessfully un-bent 2 of my RS4 reps....
Old Sep 12, 2005 | 10:12 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Sucessfully un-bent 2 of my RS4 reps....
When I got my new tires (Kumho Ecsta ASX 225/45 17) the chap at the shop mentioned that 2 of the wheels were rather un-round. After a few trips, I decided I couldn't bear the vibrations any more. So, up on the jacks the car went, underneath I rolled on my trusty rusty creeper, with a sharpie and a can of WD-40 (with straw!!). Here's how it works:
Car in neutral, brake off (make sure to chock the wheels so the car can't roll off of your jacks), line the straw on the can up with the lip of the wheel, as far towards the tire as possible. slowly rotate teh tire, watching for high spots. These will cause the straw to start to bend, and follow the wheel. Mark the beginning and end of the high spot(s) with the sharpie, and dismount the wheel from the car.
find a nice soft piece of carpet, a large pad, something soft to set the wheel on FACE DOWN. Grab your BFH (My BFH is a dull old splitting maul, with plastic on the face to prevent unneeded scarring. Now would be a good time to put some duct tape over your balance weights, to keep them from flying off when you hit the wheel..
Arrange the wheel on your soft surface in such a way that you can give it some careful strikes from your BFH. The wheel will bounce a lot. I tried standing on the sides fo the tire too, and hitting it betweeen my legs, but it didn't work too well.
after this exercise, the wheels are noticeably more round, and the annoying vibration is all but gone at all speeds (it was really annoying at 50 -75).
YMMV, but I've used this method in the past, and ressurected it with sucess over the weekend!
Boston Driver's Avatar
AudiWorld Expert
BFH returns!!!
Old Sep 12, 2005 | 10:15 AM
Head Cat Herder
25 Year Member
Default It was already out from my CV joint job, while cleaning the handle of CV grease...
I decided to have a whack at it (pun intended)...
Old Sep 12, 2005 | 10:36 AM
PepeA6's Avatar
BFH approach scares me to no end...!
Old Sep 12, 2005 | 10:51 AM
Head Cat Herder
25 Year Member
Why? It works. It's better than heating it and bending it!
Old Sep 12, 2005 | 11:38 AM
joeycuccaro's Avatar
Default Kris you always have the answers...
I just amde a post on how to unbend one of my wheels. The rear is causing a vibration around basically all speeds and its annoying as hell! I dont think i can last till spring for new wheels so im going to have to try this.
Old Sep 12, 2005 | 11:54 AM
TXurS6's Avatar
Default FAT
I used to call the BFH my "Fine Adjustment Tool"
Old Sep 12, 2005 | 11:57 AM
Head Cat Herder
25 Year Member
Love it!
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 12, 2005 | 12:01 PM
TXurS6's Avatar
Default Re: FAT
I think I picked the term up in the military. I worked on nukes ;-)
Head Cat Herder
25 Year Member
Sweet. Using a BFH on nukes.. takes some LARGE attachments to do that!
