Rear Brakes
The car has a mechanical center diff, but the diffs at each end are open, and use the braking system much like a clutch type limited slip. The only difference is that it's easier to replace brake pads than it is diff clutches ;-)
EBD (electronic brake force distribution) automatically maximizes the braking load at each wheel at any time the brakes are used. It's a 4 channel system - as is the ABS system. So basically it's trying to avoid engaging ABS until all other braking grip options are exhausted.
If the car is carrying heavy loads, you have different tires front to rear, different brake pads front to rear, they can all contribute to the EBD and/or EDL working overtime.
