Chip at high altitude?
has anyone who lives/drives up in the high country had luck with a chip? is there a difference because of high altitude? What Brand is the best?
I contacted APR with this question and never got a response.
i have heard that sealevel chips won't work correctly up here and that it may cause more problems. any advice?
To compensate MTM and O.CT make "altitude adjusted" chips - essentially de-tuned versions of their sea level and/or 93 octane chips.
All that said, there are plenty of people in the Denver area running GIAC, AMS, MTM, and O.CT chips with relatively few failures. FWIW, my advice is to go with a conservative chip like O.CT, replace your throttle body boot with an aftermarket TBB or APR Bipipe, and switch to better diverter valves like 710Ns or aftermarket DVs like Forge or Hyperboost. As mentioned, more agressive chips are available and in use here. Make sure you're comfortable with the risk if you choose to go that route. Replacing turbos isn't cheap.
Hope this helps
IMHO2, many tuners with three and four letter acronyms are too agressive with their boost curves for altitude, some even (knowingly or unknowingly) have in effect disabled the built-in altitude compensation. Personally, I would be very cautious running a chip that was not tuned for altitude. My guess is that some of the tuners don't really know what exactly to change for altitude, but that is just a guess.
Personally, I have used Sportec and MTM in my car knowing that both have been tuned for Colorado. All in all, I prefer the Sportec stuff, as it is a bit smoother and I don't hear the turbos, as I did sometimes with the MTM code. Power was comparable. My priorities are drivability and durability, not maximum power.
Of course, YMMV. Etc., etc., etc....
Oh yeah, my car is also a 2000 A6 2.7T 6spd.
You'll know you're running too much boost when you get up to 8K feet, go WOT, and hear a sound like a 10 ton tea kettle whistling in your engine bay. NOT a pretty sound!
