ESP and ABS sensors...
Old Sep 14, 2005 | 05:59 AM
endlessRR's Avatar
Junior Member
Default ESP and ABS sensors...
Ok, i've brought my A6 in 3 times to have the sensors checked due to them turning on, and this week it came on 3 times, weird times too, mostly when parked. One time it came on while driving and it flashed, stayed on for a few seconds, then turned off. Something loose? Need sensors replaced?? What's going on? Thanks...
Old Sep 14, 2005 | 07:31 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Turning on? what turned on? The ESP light?
Old Sep 14, 2005 | 07:37 AM
endlessRR's Avatar
Junior Member
Default Re: Turning on? what turned on? The ESP light?
Yep, sensor for ESP and ABS light went off a few times this week alone.
Old Sep 14, 2005 | 07:39 AM
Head Cat Herder
25 Year Member
Default well, the ABS light shouldn't blink unless there's a prolbem...
I'd hook into it with a VAG COM or other 1551/1552 type scanner and see what the ABS system is complaining about..
Old Sep 14, 2005 | 10:54 AM
vpr1980's Avatar
Junior Member
Default search the forum....a couple of ppl and i had the same problem....some sensor is failing forgot...
which one
Old Sep 14, 2005 | 10:56 AM
endlessRR's Avatar
Junior Member
Default Re: well, the ABS light shouldn't blink unless there's a prolbem...
Welp, there's a problem then. Turned the car on and ESP and ABS light went off. Got home, car off, turned it on again, lights dissapear, never went on again. What's up with this?
J. Patterson
Apr 13, 2007 10:04 AM
gilee_8
Dec 9, 2005 05:01 AM
iconoclast
Nov 18, 2005 10:40 AM
NotANumber
Jan 14, 2004 04:47 AM
MarkItZero
Feb 13, 2003 09:13 PM
