Parts Question
Old Sep 15, 2005 | 06:34 AM
douglasthescot's Avatar
New Member
Default Parts Question
OK, I know there are a million links to Parts Suppliers on Stoney's page, but I never seem to find what I need, so I'll cut to the chase -
For a 99 2.8Q, I need to get <b>Valve Cover Gaskets</b> and <b>Spark Plug Wires</b>. I changed the plugs last night and I had oil on 2 of the 6 boots. One of them was GUSHING. Electrodes were not wet though, and side of block under those areas were black from oil so it looks pretty open and shut.
Any "gotchas" on <b>changing the gaskets</b> that I should be aware of?
Thanks~!
Old Sep 15, 2005 | 07:25 AM
A6sport's Avatar
Default The gotcha is: hope that it's the valve cover gaskets...It could just as likely be the dreaded...
Cam seals leaking!
Old Sep 15, 2005 | 07:44 AM
New Member
Default Yikes, hope not!
Would you find oil leaking onto the block if that were the case?
Old Sep 15, 2005 | 07:53 AM
slimmn's Avatar
Junior Member
Is this on the oil cap side? If the seal or cap is bad, this could happen too.
Old Sep 15, 2005 | 08:24 AM
New Member
Default One on each side, but....
I &lt;b&gt;did&lt;/&gt; notice, come to think of it, that the seal for the oil cap seemed to pop out rather easily after I removed the cap and seemed to be a little warped.
TKS~
Old Sep 15, 2005 | 08:32 AM
Eric 2.7's Avatar
Default You definitely have leaking valve cover gaskets. Cam adjuster gasket leaks will
cause a burning oil smell in the cabin if the passenger side is leaking and oil on the front of the driver side bank.
If you don't experience an objectionable burning oil smell in the cabin or smell smoke, just replace your valve cover gaskets.
There's a great how to on www.audipages.com by Paul W. It's basically the same.
You can get the gaskets from the dealer or ECS.
Old Sep 15, 2005 | 09:41 AM
PepeA6's Avatar
Default A few lucky ones have them leaking both(oil on the block+burning oil smell)
Somebody mentioned the Audi Technicians joke that goes:
"Did you see the V6(Audi) that does not leak oil?"..since there is no such V6
Getting them done(gaskets and seals) with the TB in 3-4K miles...hope I will not leak oil for few thousand miles...
Old Sep 15, 2005 | 10:40 AM
New Member
Default Yeah...no oil smell so I'm thinking just the valve covers
and that will be a relief!
Thanks-
DE
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 15, 2005 | 05:10 PM
Eric 2.7's Avatar
Default At any rate, the cam adjuster gaskets aren't really a big deal to do. I have
done mine without taking camshafts out in about 2 hours per side (going slowly and carefully).
sabresfan
Jan 8, 2013 07:19 PM
pbev-csq
Jul 25, 2004 12:16 PM
OneThirtyEight
Jun 26, 2004 05:56 AM
Ian S.
Feb 18, 2003 12:11 AM
Hal_TT::CBP
May 16, 2001 09:12 PM
