HELP!! I need to know if a (after-market) Audi A4 rims (17-inch) will fit a 99 Audi A6 quattro sedan
Old Sep 15, 2005 | 11:23 AM
99audia6q's Avatar
New Member
Default HELP!! I need to know if a (after-market) Audi A4 rims (17-inch) will fit a 99 Audi A6 quattro sedan
please post your replies here and/or email me at gaethong@usa.com
Thanks!!
Old Sep 15, 2005 | 11:25 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Yes, they should.
Old Sep 15, 2005 | 11:38 AM
99audia6q's Avatar
New Member
Default Re: HELP!! I need to know if a (after-market) Audi A4 rims (17-inch) will fit a 99 Audi A6 quattro
Thanks for the quick answer. That's what I thought too. HOWEVER, when I asked the tiredirect guys over the phone, he said that it might not because of the bigger(fatter) size of the brakes in A6 quattro vs. A4. eventhough the size is going up from a stock 16-inches, it might stick out more than the stock rims due to the brakes. did you (or anyone) actually tried this? are they definately 100% interchangeable, regardless of manufacturers?
Old Sep 15, 2005 | 11:41 AM
Head Cat Herder
25 Year Member
Default I've swapped wheels between my A4 and my A6, with no problems...
The brakes are the same between a 99 A6 and all years of B5 A4.
Old Sep 15, 2005 | 11:42 AM
Boston Driver's Avatar
AudiWorld Expert
Default The OEM ET45 version fit over the LARGE HP2 caliper of the 2.7T, which is larger than your brakes
...so, it should be fine as long as the offset is not higher than ET45. Most "replica" wheels will have ET35, so it should be fine.
Old Sep 15, 2005 | 11:43 AM
AudiWorld Expert
...sounds like it should work just fine, but did you need the BFH to make the wheels fit?
Old Sep 15, 2005 | 11:46 AM
Head Cat Herder
25 Year Member
Default Nope. But, I've needed the BFH to get wheels OFF the car..
Darn rust..
Branko Spoljar
Jun 5, 2018 02:04 PM
Ricardo22
Wheels & Tires Discussion
Oct 2, 2015 08:01 AM
midipro123
Sep 13, 2005 04:06 AM
JJBliss
May 7, 2003 12:31 PM
01-2.8spt-philly
Jun 28, 2001 12:28 AM
