Heavy duty tie rods and 245's= toasted tires?
Old Sep 16, 2005 | 04:51 PM
Morgan Hill Madman!!'s Avatar
Default Heavy duty tie rods and 245's= toasted tires?
I got the ECS heavy duty tie rod ends that are bigger and 245/40/18 Kumho's and lost both front tires after 5 k miles due to rubbing through on the 3/4" inside portion of the tire. They turn fine when stationary so I can see why nobody caught it during the mount but the closest thing to the tire that could do this is the tie rod end and it must be flexing under load? Anybody else have anything close to this happen? My new tires look like shredded wheat on the inside.
Old Sep 16, 2005 | 05:00 PM
AudiForYou's 2.7T's Avatar
Default I have 255 and Meyle heavy duty tie rod ends. No issues.
Did you get an alignment after having those tie rod ends installed? A misaligned front end will shred tires.
Old Sep 16, 2005 | 05:16 PM
Default Bizarre.....
I had an alignment right after I put the tie rods in but this is more of a rubbing issue that is grinding the inside 1/2-3/4" inch of tire off. More on the top of the sidewall than the tread area. Any other ideas?
Old Sep 16, 2005 | 05:21 PM
im_cecil's Avatar
Wheel specs? Upper control arm?
Old Sep 16, 2005 | 05:27 PM
Default Ctrl Arms OEM new, Wheels TSW 18's 32 offset....
HR coilovers dropped pretty low. I'm thinking the lower ride height is pushing the bottom of the ball joint closer to the tire making it rub. I just looked more and it's gotta be the ball joint. I'll tear it apart tomorrow to see for sure.
Old Sep 16, 2005 | 06:53 PM
$240 worf of puddin's Avatar
Member
what is your offset and tire you're using?
Old Sep 16, 2005 | 07:31 PM
Default Re: what is your offset and tire you're using?
35mm offset and 255-40/17 Continentals.
Old Sep 16, 2005 | 08:09 PM
Default Is your car lowered at all?...
If so take a look at the very inside of the tire and let me know if see anything wierd. I swear I had no indication until my tire went flat. Only then did I notice the problem. You technically should be about 8mm worse off then me not considering the tire shape.
I'll try to post a pic tomorrow.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 16, 2005 | 10:00 PM
Member
Default what about you... are you lowered?
my car sits lower than in my pic poster (it has settled) I'm tucking a lil' tire now. 255's are the next thing on my list but'll have to wait till spring
Old Sep 17, 2005 | 06:26 AM
H&R Sport springs, and no signs of rubbage on the inside sidewall.
