When driver door is little ajar, interior light won't turn on and won't display "door ajar" in the
Old Apr 20, 2006 | 06:48 AM
A6w2.7T's Avatar
New Member
Default When driver door is little ajar, interior light won't turn on and won't display "door ajar" in the
2000 A6 2.7T
Symptom :
When driver door is little ajar, interior light won't come on and won't display "door ajar" in the cluster.
Help me plz
Thanks
Old Apr 20, 2006 | 07:25 AM
absolutcq20v's Avatar
Default Might be similar to this...
<ul><li><a href="https://forums.audiworld.com/a6/msgs/616154.phtml">Post from yesterday</a></li></ul>
Old Apr 20, 2006 | 07:54 AM
Max_A6's Avatar
Junior Member
Default redneck fix
<ul><li><a href="https://forums.audiworld.com/a6/msgs/507602.phtml">https://forums.audiworld.com/a6/msgs/507602.phtml</a></li></ul>
Old Apr 20, 2006 | 10:36 AM
A6w2.7T's Avatar
New Member
Default Also here is my fault code
Thursday,20,April,2006,13:34:52
VAG-COM Version: Release 512.1-UD
Control Module Part Number: 4B0 962 258 J
Component and/or Version: Central Lock/Alarm D32
Software Coding: 15981
Work Shop Code: WSC 05211
7 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00991 - Interior Lights
28-10 - Short to Plus - Intermittent
01566 - Activate Signal for Interior Monitor
01568 - Signal for Convenience Opening
00952 - Signal; Drivers Door Open
01571 - Signal for Seat Memory
29-10 - Short to Ground - Intermittent
01357 - Tank Flap Locking Motor (V155)
29-00 - Short to Ground
Old Apr 20, 2006 | 10:44 AM
A6w2.7T's Avatar
New Member
Can I use the latch from A4 or other models?
cardinalfan
Nov 4, 2018 06:06 AM
Cliffsay
Mar 30, 2016 10:00 AM
highmiles
Apr 27, 2013 10:20 AM
Swede Pete
Oct 23, 2004 06:13 AM
pianogrg3
Jul 26, 2004 04:27 AM
