Is it true that Mercedes has SAME Lugpattern as the A6
Old Apr 20, 2006 | 03:37 PM
ado_dado83's Avatar
Member
Default Is it true that Mercedes has SAME Lugpattern as the A6
I browsed throgh ebay and some seller said that mercedes lugpattern is 5x112 just like Audi's.
Is that true or only on some models just like with our Audis?
Old Apr 20, 2006 | 03:53 PM
urq20vt's Avatar
It is true, but the center bore and offsets are different.
Old Apr 20, 2006 | 05:12 PM
Potomac-Greg's Avatar
You would need something called "centering rings" to make them work.
Old Apr 21, 2006 | 12:56 PM
Capt William's Avatar
Default Yes, I am using BBS RK2s that came off a Mercedes
The offset for my 18x8.5" RK2s is the same whether you order it for a Mercedes or Audi, 32ET. Many aftermarket wheels are 35ET offset but of course that is only a 3 mm difference and OEM Audi wheels are often more like 40+ET. I think some people get caught up with the idea that there is only one correct offset but there is a range that will work. If you go too far you may; hit the brake caliper, hit the fender well or put a lot of stress on the suspension. You will need the correct hubcentric rings for the Audi because the ones for Mercedes are different. With the BBS wheels you need rings whether you are putting them on a Mercedes of Audi (or probably any other car) but they are different. I bought the rings at Tirerack for perhaps $15 per wheel.
ChevyGuy
15
Jan 18, 2015 06:07 AM
The Simps
12
Sep 10, 2013 05:00 PM
Loseph
Wheels & Tires Discussion
Nov 17, 2006 10:45 AM
germanmissile
14
Sep 21, 2005 05:23 AM
liquid62
9
Jul 23, 2002 07:03 PM
